A firmware engineer finishes integrating a display module. The hardware works. Communication is stable. But when the first operator sits down with the device, they hesitate, press the wrong button, and then ask, “Where do I confirm?” The screen is functional. The interface is not. That gap — between a working display and a usable interface — is where GUI design lives.
GUI design is one type of user interface design, but it differs from web design in its platform constraints, interaction patterns, and implementation requirements. For a detailed comparison, see our guide to the differences between web design and GUI design.
GUI design (Graphical User Interface design) is the discipline of structuring and presenting interactive elements on a screen so that users can operate a system accurately and efficiently. It applies to everything from smartphone apps to industrial control panels, covering the arrangement of buttons, menus, data fields, icons, and feedback indicators. The goal is not decoration — it is reducing the cognitive load required to complete a task correctly.
Snippet-ready definition: GUI design is the process of planning and arranging the interactive visual elements on a screen — buttons, menus, icons, forms, and layout — so that users can operate a system accurately with minimal effort. It bridges hardware capability and real-world usability, and applies across consumer software, embedded devices, and industrial control interfaces.
The practical stakes are higher in embedded and industrial contexts than they appear on a spec sheet. A display that passes electrical testing can still cause operator errors, slow commissioning, or costly retraining cycles. Understanding what GUI design actually involves — its elements, principles, and process — gives engineers and product teams a framework for evaluating those risks before they reach production.
The Main Elements of GUI Design
Windows Icons and Menus
A window is the container that holds content and controls for a specific function or task. On a desktop operating system, windows are resizable and layered. On an embedded display or industrial HMI, the equivalent is a screen state or page — a defined layout that the user navigates into and out of. The distinction matters for design: embedded interfaces typically lack the window management layer that users of desktop software expect, so each page must be self-explanatory without relying on familiar OS conventions.
Icons are visual symbols that represent actions, states, or objects. They reduce the need for text, which is useful when screen space is limited or when the device will be used across multiple languages. The trade-off is recognition: an icon that is clear to a designer may be ambiguous to an operator in a noisy industrial environment under time pressure. Icons work reliably when they have an established convention (a power symbol, a warning triangle) or when they are accompanied by a short text label.
Menus organize access to functions that don’t need to be permanently visible. A shallow menu structure — where the operator can reach any function in two or three interactions — reduces navigation errors. Deep hierarchies are faster to design but slower to use, and in safety-critical applications, they increase the chance of an operator selecting the wrong function. Before committing to a menu structure, map out the most frequent tasks and verify that the path to each one is short.
Buttons Forms and Controls
Buttons trigger actions. Forms collect input. Controls — sliders, toggles, spinners, checkboxes — adjust parameters. These three categories handle most of what a user actually does with an interface.
Buttons must be large enough to activate reliably with the input method available. On a resistive touchscreen, the minimum practical tap target is larger than on a precision capacitive panel, because resistive input registers a pressure point rather than a fingertip centroid. On a device used with gloves, targets need to be larger still. Specify tap target size based on the actual input device and the use environment — not based on what looks proportional on a design mockup.
Forms introduce error risk. Every field that requires manual text entry is a potential source of incorrect data. Where possible, replace text entry with constrained controls: a numerical keypad with a defined range, a dropdown list with validated options, or a toggle between two states. When text entry is unavoidable, provide immediate inline feedback — a field border color change, a character count, or a format hint — so the user knows whether their input is valid before they submit.
Controls like sliders and spinners are appropriate for parameter adjustment, but they require careful range and resolution design. A slider that covers a 0–1000 range on a 5-inch screen gives the operator approximately 100 pixels of travel — one pixel per ten units. If the relevant operating range is 400–600, the entire useful span occupies 20 pixels. In that case, either restrict the control range or provide a numeric entry field alongside it.
Layout and Visual Hierarchy
Layout determines where elements sit on the screen. Visual hierarchy determines which elements the eye notices first. Both affect how quickly an operator can orient themselves and complete a task.
A basic layout principle for industrial interfaces is zone separation: place status information (what the system is doing) in a consistent location, place controls (what the operator can do) in a separate zone, and place alerts (what needs attention) in a position that does not require deliberate navigation to find. When status, controls, and alerts are mixed together without spatial separation, operators must scan the entire screen on each interaction.
Visual hierarchy is established through size, contrast, color, and spacing — not through ornamentation. A large, high-contrast value at the top of a data display tells the eye where to look first. A small label below it confirms what that value represents. Reversing the sizes — large label, small value — forces the eye to work backwards. In time-sensitive applications, that extra fraction of a second matters.
Color carries functional meaning in industrial interfaces: red typically signals fault or danger, green signals normal operation, amber signals caution. Introducing color for purely aesthetic reasons — using red as an accent on a button that performs a routine function — creates ambiguity. Check every use of color against the functional meanings already established in the interface.
Common GUI Design Principles
Consistency and Familiarity
Consistency means that the same action always looks and behaves the same way throughout the interface. A “Confirm” button should have the same visual appearance, position pattern, and behavior on every screen where it appears. When it changes — different color on one screen, different position on another — the operator must re-evaluate each interaction rather than relying on learned behavior.
Familiarity means drawing on conventions the operator already knows. Directional arrows that behave like directional arrows. A home icon that returns to the main screen. A progress bar that fills left to right. Departing from established conventions requires the operator to learn new behavior, which extends commissioning time and increases error rate during the learning period. The trade-off is justified only when a familiar convention would be genuinely misleading in the specific application context.
One concrete verification: before finalizing the interface, list every interactive element and confirm that each one follows the same visual and behavioral rules throughout all screen states. Inconsistencies found at this stage are far cheaper to fix than inconsistencies found during operator training.
Feedback and System Status
Every action the operator takes should produce observable feedback. A button press should visually depress or change state. A submitted form should confirm receipt or report an error. A process that takes more than a second or two should display a progress indicator. Without feedback, the operator cannot tell whether their input was registered — and may press again, cancel prematurely, or assume the system has failed.
System status — what the machine is currently doing — should be continuously visible without requiring navigation. On an industrial control panel, this typically means a persistent status bar or indicator zone that shows operating mode, current process step, and any active alarms. “The screen is bright enough on the bench” is a common observation during prototype review; the more useful question to ask is whether the status information is readable after several hours in the actual installation environment, under ambient lighting and at the operator’s natural viewing angle.
Feedback also applies to error states. An error message that says “Error 47” tells an operator nothing actionable. A message that says “Temperature sensor offline — check connector J3” gives them a starting point. Design error messages for the person who will read them in the field, not for the engineer who wrote the firmware.
Simplicity and Usability
Simplicity in GUI design does not mean removing features. It means removing elements that are not needed for the task at hand. Every additional element on a screen — an extra label, a decorative line, a status value that is never consulted during normal operation — competes for the operator’s attention. The appropriate measure is not “does this element add information?” but “does the operator need this information at this moment?”
Usability is measurable. Task completion rate, time-on-task, and error rate during structured observation sessions give concrete data on whether the interface performs as intended. These measurements are more reliable than design team review, because the design team has complete knowledge of the interface and cannot experience it as a new user does.
A practical threshold: if an operator who has received standard training cannot complete a primary task correctly on the first attempt, the interface has a usability problem regardless of how well it passes a visual design review.
The GUI Design Process
User Research and Requirements
GUI design starts with understanding who will use the interface, what tasks they need to complete, and in what environment. For an embedded device or industrial panel, this means identifying operator skill level (trained technician vs. general line worker), task frequency (setup once vs. repeated daily), and environmental constraints (gloves, noise, lighting, viewing distance).
Translate observations into requirements before opening any design tool. A requirement like “the operator must confirm a parameter change within 3 seconds from a distance of 60 cm in ambient light of 500 lux” is actionable. A requirement like “the interface should be easy to use” is not. Concrete requirements allow later decisions — font size, button dimensions, contrast ratio — to be verified against a defined standard rather than evaluated by opinion.
Pay particular attention to error scenarios during requirements gathering. What happens when the operator enters an out-of-range value? What should the screen show when communication with the host controller is lost? These edge cases are often absent from early requirements and expensive to address after the interface is built.
Wireframes and Prototypes
A wireframe is a structural representation of a screen layout — positions of elements, zones, and navigation paths — without visual styling. Working at the wireframe stage keeps design discussion focused on structure and task flow, rather than on color and typography, which are easier to change but tend to dominate review sessions.
Prototype fidelity should match the decision being tested. A paper sketch is sufficient for evaluating navigation flow between screens. A medium-fidelity digital prototype is appropriate for testing control layout and tap target size. A high-fidelity prototype running on the target hardware is necessary for evaluating readability under actual display brightness, ambient light, and viewing angle conditions.
For embedded and industrial displays, running the prototype on the actual hardware matters earlier than most schedules allow for. Brightness, color rendering, and touch registration on the physical panel may differ substantially from what a monitor-based design tool shows. A layout that looks balanced on a 1920×1080 monitor preview may have a different visual weight on a 7-inch 800×480 panel mounted at an angle in a cabinet.
Usability Testing and Refinement
Usability testing does not require a formal lab. Structured observation of three to five representative users attempting defined tasks will surface the majority of significant usability problems. The key is to observe without intervening — if the tester pauses, hesitates, or makes an error, note it and continue. Do not explain or correct during the session.
Prioritize issues by frequency and severity. An error that occurs on a primary task for every user is a higher priority than an inefficiency that occurs on a rarely used configuration screen. Fix high-priority issues before retesting — layering refinements on top of unresolved structural problems produces misleading results in subsequent test rounds.
Document each change and the rationale for it. During later development phases, when schedule pressure produces suggestions to “simplify” the interface by removing features, having a record of why specific design decisions were made — and what problem they solved — allows the team to evaluate those suggestions against evidence rather than preference.
Common GUI Design Mistakes
Several recurring mistakes cause GUI designs that work correctly in testing to underperform in the field.
Overloading a single screen. Combining too many controls, values, and options on one screen forces the operator to parse large amounts of information before acting. The correction is not always to split the screen into multiple pages — sometimes it is to identify which elements are needed simultaneously and which can be accessed on demand. Separate what must be seen together from what merely could be seen together.
Inconsistent navigation patterns. Using a back button on some screens and a home icon on others, or placing the confirm action on the left on one page and on the right on another, creates hesitation at each transition. Map navigation patterns across all screens before building — not after — and verify consistency before user testing begins.
Designing for average conditions. A design validated on a bench under ideal lighting, with a standard adult hand, and at a comfortable desk height may fail when deployed at waist height on a factory floor, under variable lighting, by an operator wearing work gloves. Test under representative conditions, not ideal ones.
Using color as the only differentiator. An interface that distinguishes active from inactive states, or normal from fault conditions, using color alone is inaccessible to users with color vision deficiencies — and unreliable on displays with color calibration drift over time. Pair color with shape, icon, or text to make distinctions redundant.
Deferring error state design. Error messages, timeout screens, and communication loss states are frequently left until late in development and then designed quickly. These are exactly the states in which operators need the most guidance. Design error states with the same care as normal operation states, and verify them during usability testing.
Ignoring the commissioning phase. Initial setup screens, calibration interfaces, and configuration menus are used infrequently but are critical to getting a machine running correctly. Errors during commissioning can produce faults that are difficult to trace. Test commissioning workflows with the actual commissioning engineer, not just the end operator.
Frequently Asked Questions
What is the difference between UI design and GUI design?
UI (User Interface) design is the broader category — it includes any interface through which a user interacts with a system, including physical controls, voice input, and tactile feedback. GUI design specifically refers to graphical interfaces displayed on a screen. All GUI design is UI design, but not all UI design is GUI design.
Does GUI design apply to embedded and industrial displays, or only to software applications?
GUI design applies to any system where an operator interacts with a screen. Industrial HMI panels, embedded control displays, vending machine interfaces, and EV charger screens all require the same foundational work — task analysis, layout structure, feedback design, and usability testing — as consumer software applications. The constraints differ, but the discipline is the same.
How early in a hardware project should GUI design begin?
GUI design should begin during requirements definition, before hardware is finalized. Screen size, touch technology, and display brightness all affect what GUI layouts are practical. Starting GUI design after hardware is locked often produces layouts that fight the physical constraints of the display rather than working with them.
What makes a GUI suitable for industrial use specifically?
Industrial GUIs typically prioritize legibility under variable lighting, large tap targets for gloved hands, clear differentiation between normal and fault states, and short navigation paths to critical functions. Aesthetic minimalism is a byproduct of these functional requirements, not a design goal in itself. Certification requirements for the application — safety category, industry standard — may also constrain specific interface elements.
How do you evaluate whether a GUI design is good enough before production release?
Run structured usability tests with representative users completing primary tasks without assistance. Measure task completion rate, time-on-task, and error count. Test under representative environmental conditions — lighting, mounting angle, operator posture. A GUI that passes these tests against predefined acceptance criteria is a more reliable indicator of field readiness than a design review by the development team.
GUI design decisions made early in a project — screen layout, navigation structure, feedback patterns — are significantly cheaper to revise at the wireframe stage than after firmware is integrated. The most common source of late-stage rework is not hardware failure; it is interface behavior that made sense to the designer but not to the operator.
For teams working with embedded display hardware, the interface firmware workload is a real integration constraint. One way to reduce that workload is to select display hardware with built-in controller capability. STONE’s industrial display modules integrate a 1 GHz Cortex-A8 CPU, 256 MB flash, touch input, and a JSON-based UART command set into a single module, which shifts GUI rendering responsibility off the host MCU and allows the host firmware to focus on application logic rather than display management. The Industrial Series operates across -40°C to +85°C and carries a 3-year warranty (per product listing data).
Engineer path: If you are evaluating display hardware for a GUI integration project, start with the electrical and communication interface specifications before committing to a platform. Review the STONE datasheets to compare interface options, temperature ratings, and memory specifications against your application requirements.
Buyer / PM path: Selecting display hardware that includes GUI development tooling and documented communication protocols reduces the integration timeline and the number of firmware iterations required before operator testing. Evaluate the STONE Industrial Series against your project’s environmental specifications and delivery schedule to determine whether the module-level architecture fits your qualification window.
