What Makes a Display Truly Waterproof?
Rugged displays are everywhere in modern industry today. You see them at gas stations and car washes. They work at factory floors in all conditions. Rain and snow don’t stop them. They survive high-pressure cleaning in food plants. The demand grows stronger every year.
Waterproof displays differ from standard screens in key ways. True waterproof units handle full water immersion safely. They seal against dust, chemicals, and harsh weather. Engineers must know the exact protection level needed. One wrong choice leads to costly equipment failures.
This guide covers everything about selecting waterproof screens. You will learn IP ratings, brightness needs, and touch options. We explore real uses from marine navigation to outdoor kiosks. Installation tips come from 14 years building TFT LCD modules.
Understanding IP Ratings and Standards
The IP Rating System Decoded
IP stands for Ingress Protection. Two numbers tell the whole story. The first digit shows dust protection. The second digit shows water protection.
First digit scale runs from 0 to 6:
- 0: No protection at all
- 1: Protected against large objects over 50mm
- 2: Protected against objects over 12mm
- 3: Protected against objects over 2.5mm
- 4: Protected against objects over 1mm
- 5: Dust protected (limited entry allowed)
- 6: Dust tight (complete seal)
Second digit scale runs from 0 to 9:
- 0: No water protection
- 1: Dripping water vertically
- 2: Dripping water at 15° angle
- 3: Spraying water up to 60°
- 4: Splashing water from any direction
- 5: Water jets from any direction
- 6: Powerful water jets and waves
- 7: Immersion up to 1 meter for 30 minutes
- 8: Continuous immersion beyond 1 meter
- 9K: High-pressure, high-temperature spray
Common ratings for industrial displays:
- IP65: Dust tight, protected against water jets
- IP66: Dust tight, protected against powerful jets
- IP67: Dust tight, handles temporary immersion
- IP69K: The highest rating, resists steam cleaning
Here’s what these ratings mean in real use:
| Rating | Dust Protection | Water Protection | Typical Use |
| IP54 | Dust protected | Splash resistant | Indoor industrial |
| IP65 | Dust tight | Water jet resistant | Outdoor kiosks |
| IP66 | Dust tight | Powerful water jets | Car wash, marine |
| IP67 | Dust tight | Immersion 1m/30min | Ruggedized mobile |
| IP69K | Dust tight | High-temp/pressure wash | Food processing |
NEMA Standards for North America
NEMA ratings serve the same purpose as IP ratings. They’re more common in North American markets. Equipment buyers often see both ratings listed.
NEMA 4 provides basic outdoor protection. It handles rain, snow, and ice formation. It also resists windblown dust. This suits most outdoor applications.
NEMA 4X adds corrosion resistance. The “X” means extra protection against rust. Stainless steel or special coatings provide this benefit. Use this for coastal areas or chemical plants.
NEMA 6P offers the highest protection. It withstands temporary submersion and powerful water jets. This matches IP67 or higher ratings.
The correlation between standards:
- NEMA 4 ≈ IP65
- NEMA 4X ≈ IP66
- NEMA 6P ≈ IP67
Water Resistant vs. Waterproof: The Critical Difference
Marketing terms confuse many buyers. “Water resistant” sounds protective but it’s not waterproof. The distinction matters greatly.
Water resistant displays handle splash and spray. Ratings from IP54 to IP65 fall in this range. They work fine indoors with occasional moisture. Don’t use them for outdoor rain exposure.
Waterproof displays seal completely against water entry. IP67 and IP68 ratings mean true waterproof construction. These units survive full immersion for specific times. They’re built for marine and outdoor use.
Water and dust resistance combines both protections. The first IP digit (dust) must be 5 or 6. The second digit (water) should be 5 or higher. This dual protection ensures long life in harsh conditions.
Optically bonded screens add another layer of protection. The LCD bonds directly to the front glass. No air gap exists between layers. This prevents internal condensation and improves clarity. It also adds impact resistance and reduces glare.
Key Technical Specifications That Matter
Brightness Requirements for Outdoor Visibility
Indoor displays work fine at 250 to 350 nits. Office lighting doesn’t challenge screen visibility. Outdoor conditions demand much more brightness.
Sunlight readable displays start at 1000 nits minimum. Direct sunlight measures 80,000 to 100,000 nits on a bright day. A 1000-nit screen provides just enough contrast. Users can read content but it’s not ideal.
High brightness units deliver 1500 to 2500 nits. These excel in direct sunlight exposure. Content appears crisp and clear. Colors stay vibrant even at noon. This brightness level costs more but eliminates readability complaints.
Modern waterproof monitors include ambient light sensors. These sensors measure surrounding light levels. The display adjusts brightness automatically. This saves power indoors while maximizing outdoor visibility.
LED backlight technology makes high brightness possible. Old CCFL backlights couldn’t reach these levels. LEDs also last longer and use less power. They generate less heat in sealed enclosures.
I’ve installed displays from 500 to 2500 nits over 14 years. The 1200-nit sweet spot works for most outdoor kiosks. Gas stations and drive-thrus perform well at this level. Marine navigation needs 1500+ nits for deck visibility.
Touch Screen Technology Options
Touch screen functionality adds complexity in waterproof designs. Water droplets can trigger false touches. Gloves block some touch technologies. Engineers must choose carefully.
Capacitive multi touch technology dominates modern displays. It supports 10-point multi-touch gestures. Response feels smooth and accurate. This technology works through thin gloves.
Projected capacitive (PCAP) offers the best waterproof performance. It detects touches through thick cover glass. The glass protects internal components completely. PCAP can ignore water droplets with proper tuning.
Resistive touch still appears in some industrial displays. It works with any object including thick gloves. The downside: poor multi-touch and lower clarity. Water doesn’t affect performance but heavy rain makes it difficult to use.
Water drop rejection has improved dramatically. Modern algorithms distinguish between finger touches and water. The system increases touch pressure threshold when rain is detected. Users press harder but functionality continues.
Some displays offer glove mode settings. This increases touch sensitivity for thick work gloves. The trade-off: more false touches from water. Turn on glove mode only when needed.
Construction Materials and Durability
Housing material determines corrosion resistance and longevity. Three main options dominate the market.
Stainless steel provides excellent corrosion resistance. SUS304 grade works for most applications. It handles rain, humidity, and mild chemicals. SUS316 offers superior protection. Use it for marine environments and food processing. Salt spray destroys lesser materials quickly.
Aluminum alloy costs less than stainless steel. Anodized finishes protect against corrosion reasonably well. Ruggedized aluminum works for outdoor kiosks and signage. It’s lighter than steel, which helps with mounting.
The front glass takes constant abuse. Tempered glass provides basic impact resistance. Gorilla Glass or similar strengthened glass resists scratches better. Thickness matters too: 3mm minimum for outdoor use, 4-6mm for vandal-resistant applications.
Sealed connectors prevent water entry at cable points. Standard connectors fail quickly in wet conditions. M12 and M16 military-grade connectors provide reliable sealing. They withstand vibration, moisture, and temperature swings.
Gasket materials seal the front bezel to the housing. EPDM rubber works well for general use. Silicone handles extreme temperatures better. The gasket compresses to create a watertight seal. Replace gaskets every 3-5 years in outdoor installations.
Display Types for Different Applications
Industrial and Manufacturing Displays
Factory floors demand reliable monitor solutions that survive daily abuse. Dust, vibration, and cleaning chemicals challenge standard screens.
Factory automation systems use sealed displays for process control. Operators monitor production from these interfaces. The screens must work 24/7 without failures. IP65 rating suffices for most factory environments. Chemical exposure requires IP66 or higher.
Process control interfaces connect to PLCs and SCADA systems. Response time matters for real-time monitoring. Touch input speeds up parameter adjustments. STONE’s TFT display modules integrate easily with standard industrial controllers. The UART interface connects to PLCs directly.
Machinery HMI panels mount directly on equipment. They face oil, coolant, and metal particles. Sealed construction prevents internal contamination. Operating temperature range matters here: -10°C to 60°C covers most needs.
Chemical resistance varies by housing material. Stainless steel resists most industrial chemicals. Aluminum may corrode with strong acids or bases. Check compatibility before specifying materials.
| Application | Min IP Rating | Brightness | Special Features |
| Factory Floor | IP65 | 500 nits | Chemical resistant |
| Outdoor Kiosk | IP65 | 1000 nits | Anti-glare, vandal-proof |
| Car Wash | IP66 | 800 nits | High-pressure resistant |
| Marine Navigation | IP67 | 1200 nits | Salt spray resistant |
| Food Processing | IP69K | 600 nits | High-temp washdown |
Outdoor Digital Signage Applications
Digital signage transforms outdoor advertising and information delivery. These displays face sun, rain, and temperature extremes daily.
Transit hubs use large-format outdoor displays for schedules and announcements. Passengers expect clear visibility in all weather. Brightness above 1500 nits ensures readability. Anti-glare coatings help in direct sunlight.
Drive-thru menu boards must withstand car wash levels of water. IP66 rating handles powerful rain and spray. High brightness (1200+ nits) works against headlight glare at night.
Retail outdoor kiosks provide self-service information. Vandal resistance matters as much as weather protection. Thick front glass deters damage. PCAP touch works through 6mm glass easily.
UV-resistant coatings extend display lifespan outdoors. Sunlight degrades plastics and causes yellowing. Special coatings and materials prevent this degradation. Expect 5-7 years of outdoor life with proper protection.
Marine and Transportation Applications
Marine environments present extreme challenges. Salt spray corrodes everything. Water is constant. Vibration never stops.
Cockpit navigation displays must survive harsh seas. IP67 minimum rating ensures water doesn’t enter. SUS316 stainless steel resists salt corrosion. Bonded screens prevent fogging in temperature swings.
Fleet management systems track vehicles across continents. The displays face desert heat and arctic cold. Operating range from -30°C to 70°C covers most needs. Heaters and fans aren’t possible in sealed units.
Heavy vehicle instrumentation endures constant vibration. Solid-state construction with no moving parts helps. Shock mounting reduces vibration transmission. STONE modules use robust solder joints and secure connectors.
Marine chart plotters need sunlight-readable screens. Deck visibility requires 1500-2000 nits minimum. Touch functionality must work with wet fingers. Water rejection algorithms prevent false inputs from spray.
Food Processing and Clean Rooms
Food processing demands the highest protection level. High-pressure, high-temperature washdown happens daily. IP69K rating handles this extreme cleaning.
Steam cleaning at 80°C with 80-100 bar pressure destroys standard equipment. IP69K seals withstand this assault. SUS316 stainless steel resists food acids and cleaning chemicals.
FDA-compliant materials matter for food contact areas. While displays don’t touch food directly, regulations often apply. Smooth surfaces without crevices prevent bacteria growth. Easy sanitization reduces contamination risks.
Temperature range extends lower for cold storage areas. Some displays operate down to -20°C or -30°C. This requires special LCD display formulations and heaters.
Clean rooms for pharmaceuticals or electronics need dust-tight seals. IP65 minimum prevents particle emission. Flat, sealed front surfaces allow easy wiping. No fan vents or openings can exist.
Advanced Features Worth Considering
Optical Bonding Technology Benefits
Optical bonding isn’t just a premium feature. It solves real problems in outdoor displays.
The air gap between LCD and front glass causes multiple issues. Sunlight reflects off both surfaces, creating glare. Condensation forms in temperature changes. Impact can crack the LCD while glass stays intact.
Bonding eliminates the air gap completely. A clear optical adhesive fills the space. Light transmission improves by 10-15%. Contrast increases dramatically in bright conditions.
Condensation and fogging disappear with bonding. No air gap means no moisture can collect. This matters in marine applications and cold climates. Temperature swings from -20°C to 40°C won’t cause fogging.
Impact resistance improves significantly. The bonded assembly acts as one rigid unit. A front glass impact distributes force across the LCD. Unbonded displays often crack the LCD while glass survives.
Better sunlight readable performance justifies the cost. Bonded displays deliver 20-30% better readability outdoors. This can mean the difference between 1200 and 1500 nit requirements.
Connectivity and Interface Options
Modern displays support multiple input formats. HDMI dominates for video signals. It carries both video and audio in one cable. DVI remains common in industrial equipment. VGA still appears on legacy systems.
USB-C simplifies connections for newer devices. It can carry video, audio, and power simultaneously. One cable replaces three separate connections. Not all waterproof displays support USB-C yet.
DisplayPort offers higher bandwidth than HDMI. Use it for 4K resolution at 60Hz refresh. Industrial applications rarely need this capability.
SDI (Serial Digital Interface) serves broadcast and professional video. It carries uncompressed video over long distances. Marine and military applications often specify SDI.
Wireless connectivity remains challenging in sealed displays. Wi-Fi and Bluetooth require antennas. Antennas need openings that compromise waterproofing. Most industrial displays stick with wired connections.
UART interface offers the simplest integration for custom applications. STONE modules support UART communication with any microcontroller. This eliminates complex video drivers and protocols.
Smart Features That Add Value
Ambient light sensing automates brightness adjustment. A light sensor measures surrounding conditions. The display increases brightness in direct sun. It dims in shade or at night. This saves power and extends backlight life.
Built-in waterproof speakers add audio feedback. Touch confirmation sounds help in noisy environments. Announcements can play through the display. The speakers need IP67 rating like the display.
Remote management capabilities allow centralized control. Network-connected displays report status and errors. Brightness, content, and settings adjust remotely. This matters for distributed digital signage networks.
Multi-input switching displays multiple sources. Security monitors show several camera feeds. Control rooms switch between different systems. Picture-in-picture modes help operators.
Plug-and-play USB touchscreen drivers eliminate installation hassles. The display appears as a standard HID device. Windows, Linux, and Android recognize it immediately. No custom drivers or configuration needed.
STONE Technology’s Waterproof Solutions
Integrated TFT Modules for Harsh Environments
STONE has built rugged display technology for 14 years. We started with basic Command Set modules. Now our V series (STWI/STWA/STWC) offers intelligent integrated solutions.
Our waterproof modules integrate CPU, flash memory, and sealed touchscreen. Sizes range from 7 to 21 inches. IP65-rated versions seal against dust and water jets. This protects electronics in outdoor and industrial use.
The UART serial interface simplifies system integration. Connect to any microcontroller with simple commands. STM32, AVR, MSP430, and Arduino platforms all work. No complex video processing needed.
Free GUI designer software speeds development. Drag and drop interface elements on screen. Set up buttons, gauges, and menus visually. Generate code automatically for your MCU. This cuts development time by 40-50%.
Custom gasket and sealing solutions adapt to specific needs. Standard IP ratings don’t fit every application. We design custom seals for unique mounting requirements. Tell us your environment; we’ll provide the right protection.
Real-World Deployment Success
Over 3,000 customers worldwide trust STONE displays. Industrial automation companies choose us for reliability. Our modules run 24/7 in factories across five continents.
Partnerships with Siemens and ThyssenKrupp validate our quality. These companies demand proven performance. They integrate STONE modules in automation equipment. Failures mean production stops, so reliability is critical.
Outdoor vending machines use our sealed touchscreens. They handle rain, snow, and extreme temperatures. The displays work from -20°C to 70°C. Five years later, they still operate perfectly.
EV charging stations face constant weather exposure. Our IP65 modules resist rain and dust. Bright sunlight doesn’t stop user interaction. The screens remain readable at 1200 nits.
Intelligent locker systems in logistics centers run STONE displays. They guide users through package pickup. Touch interaction works with gloves in cold warehouses. The sealed design prevents dust infiltration.
Smart Selection Criteria for Your Project
Environmental Assessment Comes First
Start by analyzing where the display will live. Indoor or outdoor makes a huge difference. Indoor allows lower IP ratings and brightness. Outdoor demands higher protection and visibility.
Expected water exposure determines IP rating needs. Splash from cleaning? IP54 might work. Regular spray or rain? Choose IP65 minimum. Washdown or immersion? IP67 or IP69K becomes necessary.
Dust and particle levels vary dramatically by location. Clean offices need minimal protection. Factory floors generate metal particles and dust. Outdoor installations face pollen, dirt, and airborne debris.
Temperature extremes test display durability. Standard operating range: 0°C to 50°C. Extended range: -20°C to 70°C. Some special displays work -30°C to 80°C. Match the range to your climate.
Chemical exposure requires specific housing materials. Stainless steel resists most chemicals. Aluminum corrodes with some acids and bases. Ask about chemical compatibility before ordering.
Performance Requirements Drive Specifications
Required brightness depends on ambient light conditions. Indoor: 300-500 nits works fine. Outdoor shade: 800-1000 nits. Direct sunlight: 1200-2500 nits minimum.
Touch vs. non-touch affects cost and complexity. Touch adds interaction but increases failure points. Consider if users really need touch. Display-only units are simpler and cheaper.
Resolution depends on viewing distance and content type. Close viewing (under 50cm) needs 1080p or higher. Far viewing (over 1m) works fine with 720p. Text and fine details need higher resolution.
Response time matters for video and animation. Industrial control screens can accept 20-30ms. Gaming or video needs under 10ms. Most waterproof displays run 15-25ms.
Color accuracy vs. grayscale comes down to application. Full color displays cost more but show everything. Grayscale suffices for text and simple graphics. Medical and design work needs calibrated color.
Installation Planning Prevents Problems
VESA mounting patterns allow standard bracket use. 75mm x 75mm and 100mm x 100mm patterns are common. Verify mounting hole locations before ordering brackets. Some waterproof displays use custom patterns.
Panel-mount design fits into equipment panels. The display mounts from the front. Gaskets seal against the panel. This suits control panels and kiosk installations.
Open-frame displays integrate into custom enclosures. They cost less than complete units. You provide the housing and sealing. This works for OEM equipment builders.
Cable entry points need careful sealing. Each cable creates a potential leak path. Use proper cable glands rated for your IP level. Route cables downward when possible to prevent water pooling.
Power supply options affect installation complexity. AC-powered displays need separate power. DC displays can run from system power. Voltage range matters: 12V, 24V, or wide range (9-36V).
Integration with existing systems requires compatible interfaces. Check video input types available. Verify touch interface matches your controller. UART serial offers the most flexibility for custom systems.
Total Cost Beyond Purchase Price
Initial purchase price is just the starting point. Calculate total cost over the display’s expected life.
Longevity varies greatly by quality. Cheap displays fail in 1-2 years outdoors. Quality waterproof units last 5-7 years. Extended warranties cost extra but provide peace of mind.
Maintenance requirements stay minimal for sealed units. No fans mean no filter cleaning. Sealed construction prevents internal dust buildup. Budget for annual inspection and seal checks only.
Replacement part availability matters for long deployments. Will you find the same display in 3 years? Some manufacturers discontinue models quickly. Others maintain product lines for 5-7 years.
Warranty coverage typically runs 1-3 years. Extended warranties to 5 years cost 15-25% extra. This makes sense for critical applications. Factor warranty terms into total cost.
Energy efficiency affects operating costs over time. LED backlights use 30-50% less power than old CCFL. A 24-inch display might consume 30-60W. Over 5 years, this adds up in electricity costs.
| Priority | Indoor Industrial | Outdoor Signage | Marine/Mobile |
| IP Rating | IP54-IP65 | IP65-IP66 | IP67-IP69K |
| Brightness | 400-600 nits | 1000-1500 nits | 1200-2500 nits |
| Touch Type | Resistive/PCAP | PCAP (glove mode) | PCAP (waterproof) |
| Housing | Aluminum | Stainless steel | SUS316/Marine grade |
Installation Best Practices from the Field
Sealing Techniques That Actually Work
Use only IP-rated cables and connectors specified by the manufacturer. Mixing standard cables with waterproof displays creates failure points. The manufacturer tested specific cable types. Stick with their recommendations.
Apply proper torque to cable gland nuts. Too loose allows water entry. Too tight damages threads or gaskets. Use a torque wrench set to manufacturer specs. Typically 1.5-2.5 Nm for small glands.
Verify gasket condition before every assembly. Old gaskets lose compression. Cracks or tears compromise sealing. Replace gaskets during maintenance. Keep spares on hand for quick repairs.
Test waterproofing before final deployment. Spray the installed display with water. Check for any entry points. Better to find problems during installation than after failure.
I learned this the hard way on a marine project. We installed 12 displays without water testing. Three failed within weeks from connector leaks. Now we test every installation before handoff.
Mounting Orientation Matters
Consider water drainage paths when planning orientation. Water should run off, not pool on surfaces. Angle displays slightly forward outdoors. This lets rain sheet off instead of collecting.
Avoid upward-facing connectors whenever possible. Water pools around connector openings. Even sealed connectors can fail under constant water pressure. Mount displays so connectors point down or sideways.
Ensure proper heat dissipation despite sealing. Sealed displays trap internal heat. Leave air space behind the display. Don’t mount against solid walls if possible. Heat buildup shortens component life.
Account for thermal expansion in outdoor installations. Materials expand and contract with temperature. Mounting brackets need some flex. Rigid mounting can crack housings in extreme temperature swings.
Maintenance and Inspection Schedule
Regular visual inspection catches problems early. Check seals every 3-6 months outdoors. Look for cracks, gaps, or damage. Indoor displays need annual inspection only.
Clean with recommended solutions only. Harsh chemicals damage protective coatings. Alcohol-free glass cleaner works for most displays. Never use abrasive cleaners on touchscreens.
Check connector integrity annually. Verify cable gland tightness. Look for corrosion on metal parts. Apply anti-corrosion spray on coastal installations.
Monitor performance during extreme weather. Note any brightness issues or touch problems. Temperature-related failures often show patterns. Document issues to identify systemic problems.
Document any water ingress immediately. Even minor leaks indicate seal failure. Take photos and note conditions. This helps identify root causes. Repair small problems before they become failures.
Common Challenges and Real Solutions
Challenge 1: Internal Condensation
Condensation forms inside displays during temperature changes. Warm, humid air enters the enclosure. Temperature drops at night. Moisture condenses on internal components. This can short circuits or damage the LCD.
Solution: Optical bonding eliminates the main air gap. No air gap means no condensation space. This solves 90% of condensation issues.
For non-bonded displays, use desiccant packets in the enclosure. Small silica gel packs absorb moisture. Replace them every 6-12 months. This works for moderate humidity.
Ensure proper temperature acclimation before sealing. Let displays reach ambient temperature first. Don’t seal a cold display in a warm room. The trapped cool air creates condensation later.
Challenge 2: Touch Function in Heavy Rain
Rain creates false touches on capacitive screens. Water droplets register as touch inputs. Menus open randomly. Users can’t complete actions. This frustrates operators.
Solution: Modern displays include water rejection algorithms. The controller analyzes touch patterns. Single-point touches lasting under 100ms are likely water. Multiple stable points are fingers. The system filters accordingly.
Enable wet-finger detection mode. This increases required touch pressure. Real fingers press harder than water drops. The trade-off: less sensitive touch response.
Increase touch threshold during rain detection. Some displays sense rain automatically. They adjust touch sensitivity up. Users press harder but functionality continues. Sensitivity returns to normal when dry.
Future Trends in Waterproof Displays
Higher resolution 4K displays are shrinking in size. 15-inch 4K waterproof units now exist. Sharper images help outdoor readability. Text and graphics appear crisper. Expect wider 4K availability soon.
Flexible and curved waterproof screens are coming. Current technology limits waterproofing to flat displays. New sealing methods will enable curves. This opens new industrial design possibilities.
IoT sensor integration adds environmental monitoring. Displays with built-in temperature, humidity, and light sensors. They report conditions while showing content. Maintenance teams get early warning of problems.
Solar-powered outdoor displays reduce installation costs. No power cables needed for remote locations. Large outdoor signage can self-power. Battery backup handles nighttime operation.
AI-powered content adaptation improves visibility. Displays analyze ambient light and adjust content. Dark text becomes light in direct sun. Contrast optimizes automatically for conditions.
Enhanced color gamut benefits outdoor advertising. Current displays show 72% NTSC color space. New LED backlights reach 90%+ NTSC. Outdoor ads look more vibrant and engaging.
Wireless power delivery eliminates the last cable. Inductive charging works through non-metal materials. Displays could mount on glass or plastic without connectors. This solves the connector seal problem completely.
Making the Right Choice
Selecting the right waterproof display requires careful thought. IP rating determines basic environmental protection. Match it to your actual exposure level. Don’t over-spec and waste money.
Waterproof monitors enable applications impossible with standard screens. Outdoor kiosks serve customers in all weather. Factory displays survive years in harsh conditions. Marine systems guide vessels safely.
Match specifications to real environmental conditions. Engineering specifications look impressive on paper. Actual field conditions matter more. A 2500-nit display wastes power indoors. IP69K costs extra in applications needing only IP65.
Consider total cost of ownership beyond purchase price. Cheap displays fail quickly outdoors. Replacement and downtime costs add up. Quality waterproof displays last 5-7 years. Calculate the real cost over this lifetime.
STONE Technology provides industrial-grade display solutions worldwide. Our 14 years of experience shows in product reliability. From outdoor vending to factory automation, we’ve solved tough challenges. The V series modules bring intelligence and sealing together.
Contact us for customized waterproof display integration. We’ll analyze your application requirements. Our engineers will recommend the right protection level. Together, we’ll create a solution that lasts
