Display Dilemma in Deadly Cold Temperatures
In the winter of 2023, a large-scale failure occurred in the monitoring and control system of an open-pit coal mine in Inner Mongolia. When the ambient temperature plummeted to -38°C, the 37 HMI touch panels in the control center suffered from severe dragging and finally lost response completely. Afterward, the investigation found that these panels with consumer-grade liquid crystals had dropped to a response rate of 1.2 seconds/frame at -20°C – a figure that is 150 times higher than at room temperature.
This exposes the cruelest reality in the field of industrial display: ordinary TFT LCD liquid crystal material at low temperatures will form “molecular frostbite”. The rotational viscosity (γ₁) of nematic liquid crystals rises exponentially when the temperature falls below -30°C. The Japan Display Institute (JDI) has been working on this issue for some time. Japan Display Institute (JDI) test data show that the conventional TN-type liquid crystal in -40 ℃ environment response time reached a staggering 800ms, which means that even the completion of the simplest button operation, may also need to wait nearly 1 second of visual feedback.
More fatal is the failure of the touch layer, Stone industrial screen manufacturer’s technical director revealed to us: “When the temperature falls below -25 ℃, the traditional ITO conductive layer of the square resistance will increase from 200 Ω / □ storm to 2000Ω / □. This is equivalent to putting a shackle on the touch signal.” In the Harbin Railway Bureau’s equipment renovation in 2019, there was a vicious accident in which an entire batch of station displays failed to work by touch as a result.
The Redemption of the Fluorine Atom
Faced with the challenge of low temperatures, materials scientists have turned their attention to fluorine on the periodic table. The SF-4567 series of liquid crystal materials developed by Japan’s JNC in 2016 created a dielectric anisotropy Δε=-4.5 by introducing trifluoromethyl (-CF₃) into the molecular side chain. This contrasts with the physical properties of conventional liquid crystals Δε=+5.3.
“Negative dielectric liquid crystals are like putting anti-skid chains on the molecules,” explains the technologist from the Display Materials Business Unit of Merck KGaA, “Under the action of an electric field, the molecules are aligned perpendicularly to the direction of the electric field on their long axes, and this pattern of motion is much less affected by temperature.” Laboratory data show that this material can maintain a response speed of 23ms even in a -60°C environment – down from 8ms at room temperature, but sufficient to meet the needs of most industrial scenarios.
But breaking through the low-temperature limit is just the first step. During a field test at a photovoltaic power station in Qinghai, engineers discovered a new problem: the difference in material expansion coefficients caused by the temperature difference between day and night can cause micron-level gap changes in the liquid crystal box. In this regard, BOE has developed a “double spacer compensation structure”, where spacers of different heights are set at the edge of the glass substrate, so that the change of box thickness under the temperature difference of -40℃~85℃ is controlled within 0.12μm – a figure that is only 1/600th of the diameter of a human hair.
Survival Wisdom of the Driver ICs
Even if the problem of the LCD material is solved, the driver circuits can be used in extreme environments, which is not the case in the future. Even if the liquid crystal material problem is solved, the stability of the drive circuit in extreme environments is still a huge challenge. 2022, Sany Heavy Industries in Russia in the extreme cold region of the excavator HMI has appeared in the drive IC in the low temperature “strike” situation.
“Conventional a-Si TFT LCD suffer an 80% drop in carrier mobility at -30°C,” noted an engineer at Renesas Electronics’ Automotive Electronics Division, “which results in the gate voltage not being able to effectively control the rotation of liquid crystal molecules.” Their solution is to integrate a real-time temperature compensation algorithm into the RA6M3 driver IC, which dynamically adjusts the Vcom voltage through the built-in NTC sensor, with a compensation range of ±2.5V.
Even more radical is Huawei’s “pre-heating” solution for coal mining equipment. Patent CN114942632A shows that they integrated a nano-silver wire heating film with a thickness of only 0.3mm at the edge of the panel, which can raise the local temperature from -40°C to -20°C in 30 seconds.” It’s like warming up the display,“ Huawei engineers describe, ”increasing power consumption by 5%, but in exchange for 100% reliability.”
Backlighting wars on a high-temperature battlefield
If low temperatures test the physical limits of materials, high-temperature environments are more like a brutal endurance race. In the control room of a photovoltaic power plant in the Dubai desert, the display has to face the 85°C ambient temperature directly, and the battle here takes place inside each LED lamp bead.
Nichia Chemical’s test report shows that ordinary LEDs continue to work at 85 ℃ for 1,000 hours, the brightness attenuation of up to 23%. The gold wire bonding + ceramic substrate package used for industrial-grade LEDs can keep the attenuation rate within 0.5%. But the price of this solution is the cost: the price of a single industrial-grade LED is 7.8 times that of the consumer-grade.
The certification scandal that came to light in 2023 emphasized the seriousness of the problem. A German manufacturer was found to have swapped samples in the UL certification test – the special high-temperature version was sent for inspection, while consumer-grade LEDs were used in the mass production products. data from a third-party testing organization showed that the brightness uniformity of these “industrial screens” fell below the industry standard of 75% after 2,000 hours of continuous operation.
The Ultimate Verification: Graduation Exam for Industrial Screens
What kind of test does a real industrial-grade display need to go through? We obtained the internal test standards of Siemens industrial control equipment:
In mechanical vibration testing, consumer-grade products usually undergo a sinusoidal sweep of 5Hz-500Hz, whereas industrial screens are subjected to random vibration of 10Hz-2000Hz – the equivalent of experiencing a sustained earthquake on an oil pipeline. A domestic panel maker’s early samples have been in this test, due to the flexible PCB solder joint breakage led to the total loss.
The temperature cycling test is even tougher. Huawei’s mining panels were subjected to 2,000 cold and hot shocks between -40°C and 85°C, with each cycle consisting of a 30-minute hold at extreme temperatures. In comparison, the “500 cycles” test common in consumer electronics is child’s play.
The Next Generation Battlefield
As Arctic development and desert photovoltaics advance, the standard of extreme operating conditions for displays is being redefined. The nano-capsule liquid crystal technology demonstrated by Merck’s labs can already work in -50°C environments, while Corning is testing Gorilla Glass with embedded resistive filaments to solve the problem of extreme low temperatures through self-heating of the glass substrate.
But all these advances are facing the same ultimate problem: cost. Current industrial-grade wide-temperature displays are 8-12 times more expensive than consumer-grade, which explains why some device makers are still taking chances with “modified” consumer-grade panels. Perhaps, as one industry veteran put it, “In industrial displays, reliability is never about technology, it’s about cost.”
